2014 Forester Premium 6M
Hey all, quick question:
Has anyone else found it very easy to smoke the clutch in reverse? I think I've done it like... three times in the past month. :icon_redface:
I'm sure it's mostly myself being bad at manuals, but I thought I'd see if anyone else was having the same issue.
2014 Forester 2.5i 6 spd
Once you get it rolling, get your foot off the clutch. It's actually geared lower in reverse than it is in 1st. If you need small increments/very slow, do little dabs of clutch engagement rather than keeping it in constant slippage.
One caution, make sure your defroster/AC is off, you don't need the fast idle kicking on suddenly and without warning.
2015 WRX Base 6MT
No issues here, but I use the dab of clutch here and there method. Also, I don't reverse much. Stop and go traffic in Houston was enought to generate a little stink when it was new, but with almost 5000 miles on it, it's ceased doing that. No visible smoke, but I was rather sure it was toasty. Keep the mileage in mind, and make sure it's broken in before you pass judgement.
