I 2nd the rec on AC Parts House. Got my re-manufactured compressor for $215 delivered - half the price of anywhere else I found.
thank you guys for such a quick reply.
i havent quite narrowed it down to failing compressor yet, but at least i know there is hope for being able to afford it if that proves to be the case.
first, i will get a relay (its contacts are indeed burned) and a set of guages.
i want to know for sure that i am not causing my own problem by overcharging it, or undercharging it.
this forum is a gold mine! i dont know why i have only just now found it.
update:
after a quick trip to dad's house, and a lesson on how to use his guages. i find that i had overfilled the thing!
so it probably was reaching its high pressure limit real quick, and shutting off before it had time to acutally cool anything, then kicking in again, shutting off again, again again,,,,,.
this was only happening on the really hot days, anything less than 90 degrees or so and it worked fine.(it does get much colder now, and it was 82 degrees while the guages were on it)
so, the only thing left is for me to find where to get one of those relays. hopefully for less than the 50 bucks that the dealership wants for them. any suggestions?
