1 - 7 of 7 Posts
2000 Forester
I am going to replace my brake rotors and pads on my 2000 Forester L and got some Walker ThermoQuiet (TQ) pads for the front. It looks like the new pads have built in shims, that are not removable.
Should I still re-use the factory shims even though the TQ pads have built in shims?
Thanks!
-Tony
2013 XT
You don't need the factory shims if the new ones have a built in one. There probably won't be enough room if you did, if you did squeeze them in you'll make it drag the rotor and overheat / burn the pad. I did this once.:icon_redface:
2011 Forester touring 4EAT
Subaru pad kits include brake pads, shims, spring clips, and grease...........everything that you need and they are excellent pads. Why would you want to use anything other than an oem pad kit?
Or braking performance... or dust... or longevity... tons of reasons to go aftermarket.
Whatever you do, clean off the stock shims (and clips, but you will reuse these, clean them first before putting in new pads) and KEEP them. They are expensive to replace if you ever need them again... e.g. hawk hps pads with built-in shims that fall off after a while.
none none
+1 definitely keep them around.
2013 XT
This is how i fix my squeaking brakes too. The pad moves ever so slightly in the clips. (Old rotors starting to warp and the pads follow the rotor/move in the clips) Cleaning it and putting some of that brake pad grease stuff in there helped/fixed the squeaking I had.
1 - 7 of 7 Posts
