1 - 20 of 34 Posts
MY05 Forester 2.5 XT 5MT
Hi All,
It is that time again, shopping for tyres and since we haven't had a good old tyre thread in a while.........
I'm looking for summer tyres or perhaps All Seasons that still give decent performance
So far I've shortlisted:
Nokian WetGrip - New but seem to look pretty decent from this: 2019 Summer 53 Tyre Braking Shootout - Tyre Reviews
Goodyear Efficient Grip Performance
Hankook Prime 3 K125
Fuel Economy, Road Noise and Tyre Wear are less of a concern to me compared to Wet and Dry road Cornering and Braking
Most of the driving is fast country A and B roads with some slow commuting thrown in. No track use and no offroad mud use. I have some winter wheels that will need tyres but after the last couple of winters, I'm beginning to wonder if winters are worth having
Anything else I should be looking at in the 215-60-16 size?
2004 forester sti
Look no further Goodyear Eagle f1's asymmetric , if you can get them in your size, yes they are soft and no they don't wear badly they are the best for wet grip.
unfortunately rim protection is 0
Unfortunately the Eagle F1s aren't available in a 16" rim at all. The 17" rim sizes are limited. Seems with newer cars having much bigger wheels, manufacturers aren't doing performance tyres in "little" 16 and 17" wheels anymore :(
What winters do you have fitted Ian?
I ran my winters all last summer as just never got round to switching. I'm running Hankook winters and they did rather well considering they're not designed for temps over 10c
My winters are also needing to be replaced - Can't make up my mind if I'll bother with winters this time round.....Now I've said that, we'll get the best/worst snow on record :biggrin:
06 2.5XT Manual
Wintrac xtreme 215 55 17's.
They aren't in great condition, but I can't decide whether it's worth keeping hold of them and sticking them on steels just incase we decide to do anything daft over winter...like venture up to Dartmoor... but generally there is a distinct lack of snow and ice.......or just keep running them until I need new tyres in general..
06 2.5XT Manual
I did see those, do you accept pistachios or chocolate biscuits as currency? Think I might be able to muster up an unopened Jamaica ginger cake too.... to you know 😎 sweeten the deal...
2004 STi
Looking a Dunlop Sport Maxx RT2's next, reasonable price, quiet (67-68dB) and do very well in performance reviews, they look like they would suit the FSTi well. I have Dunlop SP Sport 01's on the Miata and they are great in the wet and dry on that car and are pitched as Dunlops more mid range sport tyre.
My favourite tyre in the dry was Yoko AD08R's but they are not a good all year round tyre, standing water can be a bit sketchy.
MY07 Forester 2.0X, 2.5XT 5M, 4EAT
I have been running Goodyear Efficient Grip Performance (215/55/17 98W) in our 2.5XT over the last 35k km.
The first impression was (definitely when compared to Bridgestone Turanza ER300) that the tires were a bit "marshmallowy"- definitely less stiff side wall and more balloony look...
Performance wise these are excellent for a family car- great grip wet or dry, quiet, comfortable and slightly better on petrol. These wear beautifully at <1mm/10k km- at the moment still have ~4mm left so will do another 20k or so...
Would I recommend or buy again- definitely
2004 STi
^ Update to the above post, had the Dunlop RT2's on for about a month and wow are they good. Way more grip than the Bridgestones I had on before and the road noise reduction is mega... its almost like the Bridgestones were made the same way as the ones on these...
525466
Can't really pitch them against the AD08R's as it was a completely different car but I'm really pleased for £460 a set.
Discussion Starter · #13 ·
So I've picked up some WRX 17" alloy wheels for the summer tyre plans, which gives me much more choices now.
My old wheels and tyre set up was: 215/60/16 on a 16x6.5" ET+48
My new plan is 225/55/17 on a 17x7 ET+55 Is this likely to cause rubbing on the inside?
It would give a 1.9% positive change in Diameter, which should make the speedo a little more accurate
A wheel calculator says the inner sidewall will be 0.48" / 12.2mm closer to the suspension.
A search on the wheels and tyre section gives massively varying results with some saying it will fit with no issue and some suggesting a 5mm spacer.......I don't believe the US got the 17" WRX wheels I'm sporting so keeping it in the Euro section.
2017 BRZ Manual
Foresters run a ET48 offset on the stock XT 17x7 so your 7mm nearer the strut. Can’t imagine it would be an issue. Pretty sure I tried my Legacy Spec B stock wheels (et55) on my FSTI and they were fine
Currently running Crossclimates on our XV in that tyre size. Not sure they would suit the Foz though? More suited to a mixture of surfaces and due to the tread pattern they are pretty noisy. Thoroughly recommend PS4’s for fast road use. Not sure if they do them in a 225 55 17. Not as sticky as the AD08’s in the dry but almost as good. Ruddy bloody fantastic in the wet too
06 FSTi
Instead of starting a new thread i'm just going to add on to here.
What do people recommend for a good winter/all season tyre for the FSTi? I'm getting AD08R's for summer/trackdays as I had them on my 335i and rated them highly. But want a general tyre for winter use.
2007 Cross Sport S Edition
I think winter tyres are a waste of time in this country, unless you live some where colder like up in Scotland, or you are the sort of person that runs ditch finders in the summer
06 FSTi
I generally agree with that, but AD08R's are a very good up until it gets cold and/or very wet (like it has been for the last 2months). Great on my RWD BMW because I could just hang the arse out easily, not so great when i'm driving the length of France and the traction control light is having a one man disco on the dash. So AD08R's for summer and trackdays, but need something to use the majority of the time. Michelin CrossClimate+ or Bridgestone Weather Control A005 seem to be the ones to go for.
Discussion Starter · #20 ·
Does France require Winter tyres by law?
If you have a bump in France in winter and you are without winter tyres, are you determined to be automatically at fault?
If so, I would be looking at something with the 3 peak mountain snowflake symbol on the side. Maybe The Nokian AllWeather or Goodyear equivalent?
1 - 20 of 34 Posts
