1 - 18 of 18 Posts
MY10 X
Hi There,
What would you guys suggest is the optimal tyre pressure for on road driving of a MY10 forester X with stock tyres and rims?
The placard on the car seem way too soft and spongey.
Cheers,
Brett
2008 Forester
Stock Yoko running on 32PSI all around for a while (was basing it on the sticky thing on the driver door area) then 36PSI on the rear when I tow.
Then I had to run 36PSI all around because its uneven wear on my tyres I was told..
Maybe check out the sticky on your driver side door see what is the max when towing (even when you dont) and pump it up to that amount?
2007 Forester XT manual
I usually run 36/34 F/R & bump rear up to 36 with the camper trailer which only has a towball download of about 50kg. If I'm doing extended dirt I drop to 30 all round.
2010 Subaru Forester
the sticker on the my10 foz on the car is in kPa, thats why i reffered to it
I have 210 kpa all around, although nothing wrong with bumping it up to 220 kpa. I have done that before, no problems - u get a firmer ride. Although, I wonder how it goes especially with the very hot dry summers we have over here in Western Australia.
13 Liberty GT wagon AT
Psi's
I just think my brain copes with remembering a smaller number easier- I run 34 on my 17" XT Adrenalins, little firm but seems best compromise.
08 X
Depends on the tyre type and loading.
36 for the Dueller 693 LTs; bumped up when loaded/towing the CT. Dropped by about a third for outback gibber and corrugated roads.
40 was recommended for the Dueller 697 LTs. Similar adjustments made for non-standard conditions.
1 - 18 of 18 Posts
