Definitely reasonable! My research has shown prices closer to $70 for the kit. Not sure what the difference in price here is.you can buy them through a dealer for around $12
with or without the speaker itself $12 is reasonable.
?? there's no wiring in the $70 kit either, the wiring is already in the door pillers as stock?no wiring
This is what I remember too. I've ordered them, so we'll see if anything is missing. Then I need to find a way to afford the Pioneer AVIC Z110 BT.?? there's no wiring in the $70 kit either, the wiring is already in the door pillers as stock?
$25 bucks a pair is definitly a good deal and well worth the price, you'll notice a big difference. They raise the soundfield from your feet to your chest.
Think I saw a post here somewhere about someone finding a set of aftermarket component 6.5's where the tweeter cliped in just as OEM into the pods housing
Haven't bought a set yet, so when the housing comes in, I should know what to look for. Maybe when it comes in, I'll be able to add pics, so folks can see what it looks like.I bought them but the tweeters in my component set did not fit in them. If your component set has standard 1" tweeters you should be good.
where did you try when those part numbers "don't seem to bring up anything"? post 2 & 12 not help (i.e. a dealer)? did you try (i.e. email or ring) a Supporting Vendor, specifically Annapolis Subaru or SubaruOnlineParts.com?I am actually trying to source these now. The part numers don't seem to bring up anything. I can only find the whole tweeter kit. Anyone have different part numbers or a source?
I just ordered these from subaru online parts h t t p :// subaruonlineparts.com/catalogs.htmlin relation to the thread title and the OP, if anyone goes looking for the MY09/10 housing only, part numbers, thought i'd plonk them in here. i saw the numbers somewhere else too, but i can't find them again now :icon_sad:.
RHS - 94251SC020
LHS - 94251SC030
the number on the back of both of the tweeter magnet is 86301CS240. it also has 4ohm 35W max & G08728CB.
the measurements on the oem tweets are
- tweeter magnet from the back is 25mm
- tweeter with its 4.5mm in radius black plastic housing (that then clips into the tweeter housing that clips into the door) is 34mm (measured from the back without taking the tweeter out of the housing that clips into the door).
thanks for the correction. the numbers listed above were from the back of each black part in an MY09.I just ordered these from subaru online parts h t t p :// subaruonlineparts.com/catalogs.html
The model #s listed above are actually not accurate, the correct model #s are
94251SC120
94251SC130
I have the same problem with my Hertz 1 inchers too ... definitely won't fit ... and I haven't had time to figger it out ...:shrug:I've been looking at the hot-gluing of aftermarket tweeters into the OEM tweeter locations, and I'm having problems. I've got Polk components with a 1" tweeter, but the housing that it's glued in seems to be about 1.5" in diameter. With the housing attached, the tweeter won't fit.
Is there a good way of popping the tweeters out of the housing? Is that what typically done?
