2010 dodge caravan auto
As per deadbolt in the U.S. the following are cfm specs for various turbo sizes.
Turbo Type ----------- Approx flow @ pressure
Stock Turbo ---------- 360 CFM at 14.7 PSI
IHI VF 25 ------------- 370 CFM at 14.7 PSI
IHI VF 26 ------------- 390 CFM at 14.7 PSI
T3 60 trim ------------ 400 CFM at 14.7 PSI
IHI VF 27 ------------- 400 CFM at 14.7 PSI
IHI VF 24/28/29 ------ 410 CFM at 14.7 PSI
IHI VF-30/34 --------- 435 CFM at 14.7 PSI
SR 30 ----------------- 435 CFM at 14.7 PSI
IHI VF-22 ------------- 440 CFM at 14.7 PSI
T04E 40 trim --------- 460 CFM at 14.7 PSI
PE1818 --------------- 490 CFM at 14.7 PSI
Small 16G ------------ 505 CFM at 14.7 PSI
ION Spec (stg 0) ---- 525 CFM at 14.7 PSI
Large 16G ----------- 550 CFM at 14.7 PSI
SR 40 ----------------- 595 CFM at 14.7 PSI
18G ------------------- 600 CFM at 14.7 PSI
PE 1820 -------------- 630 CFM at 14.7 PSI
20G ------------------ 650 CFM at 14.7 PSI
SR 50 ---------------- 710 CFM at 14.7 PSI
GT-30 ---------------- 725 CFM at 14.7 PSI
60-1 ----------------- 725 CFM at 14.7 PSI
GT-35R -------------- 820 CFM at 14.7 PSI
T72 ------------------ 920 CFM at 14.7 PSI
Nice list, but where's the vf39 from the sti?
Imagine it would be right where the 30/34 would be seeing as they are ussually interchangable with minimal tunning
Bland...
DOHCammin said:
seems the 30/34 are strangely close to the 22...I thought the 22 flowed [email protected] 14lbs
Admittedly, I know little to nothing about turbo's and CFM flow, etc. But I spoke with Christian from Cobb and asked him if the new vf39 Xt map could be used for a vf34. He said from his dyno testing, that the vf34 is not suited for a 2.5 liter engine. He said it falls on its face at higher RPM's... much like the stock turbo, but not quite as bad. Just thought I would share.
I think he tries to make them look different because he doesn't want to 2.0 turbo guy's using it on there vf30/34 maps. But the ones that have said they work perfecly.
If I can find one for a decent price I would much prefer it to the vf39, so I won't have to worry about the cracking problem
Bland...
