i pulled my turbo today to fix the oil return bolt leaking problem, and also replaced my hose and the hose clamps. the butterfly clamps don't even hold at all. so i used the normal screwing kind.
put the clamp and hose on the turbo first so you can tighten it easily. then as you drop turbo in line up the bottom part of the hose to the lower oil return spot.
since i used screwing clamps instead of the the pinching, it was MUCH easier to clamp the lower one with a long flathead screwdriver, rather than trying to stick long needle nose to pinch. it took mere mere moments to tighten the lower one with a long flathead.
the hose i got from orchard supply was $1.59 for a foot. 5/8" inner diameter, and the hose looked the exact same as the OEM one. black heater hose
i cut the hose about an inch longer than the OEM one, that way when i positioned the turbo, i could push the hose down further on that lower return part so i didn't have to put the clamp higher up. since the clamp spot was now lower, it was easy to use the flathead on it
A replacement for hose on most cars and light trucks. Designed for normal duty service. Withstands the abuse of corrosive solutions and additives. Resists weathering to provide a long, trouble-free service life. EPDM tube construction. Black, with spiralpolyester reinforcement construction. Resists temperatures from -40 to 212 degrees Fahrenheit.
