Installed the following items today:
1. Samco turbo inlet and afterMAF hose
2. Grimmpseed AOS
3. Perrin BOV hose
4. PTP turbo blanket
I'm glad I replaced the stock turbo inlet because the inlet connection to the turbo was not so great. When I did the turbo swap last August I didn't want to over tighten the clamp on the stock inlet for fear of damaging it and as a result, I'm not sure the clamp was tight enough to make a leak-proof seal.
The stock turbo inlet came right out, with the help of a large pair of channel locks and a hacksaw blade.
The biggest surprise was once I had the inlet out, there was a pile of old acorns under the intake manifold. I guess the local chipmunks had been partying there this past winter.
The Samco inlet went in without much of a fuss and lined up perfectly with the turbo and other hoses. I did not have to remove the IM or any other items to squeeze the Samco inlet into place. The afterMAF hose required some trimming to get a perfect fit.
In the photo below, you can just see the PTP turbo blanket, which was easy to get on with the Perrin TMIC and SPT heat shield out of the way. Also, the Grimmspeed AOS was easy to install with the TMIC and heat shield out of the way too. I like how the stock engine cover hides all of the extra hoses and maintains a neat appearance.
The car runs well with no unusual noises are CELs. I'll be getting back on the dyno soon to get my tune tweaked for these latest mods.
2. Grimmpseed AOS
3. Perrin BOV hose
