MY11 WRX STi Sedan 6MT
MY99 S-Turbo -MHI TF035
thats what i thought just wanted comformation ,well thats a result as this one i just brought has td04 onit ,am i still ok to run it up to the 0.8 over boost even with the slightly bigger turbo onit the only other mod is a blitz nur spec exhaust
thought it felt quicker than the other 2 foresters ive had
Emeritus Forum Staff
Yes, it should be... though it probably won't give you much extra grunt without a remap - about 10bhp IIRC.
thanks for your advise guys just one more thing if i fit a fuel cut defencer what boost can i run ,just cant afford the remap at the mo ,i have a lm-1 wideband to check fueling
cheers
Just a thought........... if its already fitted with a TD04, maybe its been remapped??? or do you know otherwise?
Discussion Starter #7
Good ? not as far as i know it was a cheapy off ebay and just came with a crappy rotten back box and steering which near on killed me on the way home ,luckly i sorted that with some new rack bushes as im a super pro dealer it was just when i looked over it i found the td04 and thought im sure thats not standard ,its more than likely that the turbo went and they couldnt get a td35 ,if its been ecutek'ed theres no way of visable telling
