1 - 7 of 7 Posts
G
has anyone installed a Boost/Vac gauge themselves and was it easy? also where did you mount it?
G
a minor factory gauge factoid/observation
I have the (dealer-installed) factory column-mounted Turbo Gauge in my shiny new '06 FXT. One thing I've noticed at night is that the gauge illumination appears to cover only the top half (positive boost territory) of the gauge between the 9 0'clock and 3 o'clock needle positions. For the bottom half of the gauge, there's either a light that doesn't work very well, one that doesn't work at all, or no illumination of that range by design. Can anyone else with the factory column-mounted gauge comment?
The Modfather
at the bottom of the page in my first link you will see a shot of the gauge at night.
2009 Forester XT Limited
Does the OEM gauge dim with the interior lights? and has anyone used the "condoms" to change it to a green color? How about the best mounting spot as to not block other things. I was thinking about as far to the right as i could. Maybe it would only block the upper RPM area that i would never get to anyway
1 - 7 of 7 Posts
