41 - 60 of 79 Posts
Heads up on the first oil change by Subaru. I was sworn to twice that the dealer had the old (good) filters on hand and the TSB did not apply to my '22 Forester since they were not using the replacement filters. When I requested a look see at the filters in the parts dept. lo and behold all they had were the replacement filters and no original ones on hand. When I showed the service manager the filter and TSB, she said "oops". Since my car was being serviced as we spoke, I was hoping it could be corrected. A very short time later the car was sitting outside ready for pickup. The service manager assured me the TSB had been accomplished. I highly doubt that was the case as the time elapsed between my bringing the matter to her attention and the car being ready would not have allowed for the full TSB accomplishment. The replacement filter is the one referenced in the TSB.
2018 Forester XT Limited CVT
@bigbird1 Does Canada get the black Tokyo Roki filters (same as installed at the factory) or do you get the SOA blue Fram?
My 2018 XT came with the black 15208AA160 but I have been putting the blue 15208AA15A in it every 10,000 km (currently at about 85,000 km).
When I saw this thread I thought I should go and get some filters because I had used my last one and last crush washer during the last oil change. I went to get the filters only a couple days ago. My local dealership had lots of the 15A. I asked how many were in a box and the parts guy said 12. I didn't want that many so I bought 6 and 6 crush washers, figuring that would last me until they get their supply chain worked out.
Maybe I should have gotten 12? That many might last me the life of the car. 85,000 km plus 120,000 km.
2020 Forester Touring; 2017 WRX Limited
Being aware of the oil filter replacement TSB, I contacted the dealer that I use frequently and asked to purchase 6 of the Fram-made 15A filters, noting that I did NOT want the replacement filters. I was sent the replacement filters, anyway. In grad school, I learned about the concept of face validity, basically, if it looks good, it might just be good. Certainly not recommended for serious work. In visually comparing the remaining 15A filter that I have with the replacement filter, the latter seems to have been hastily produced.
It would be interesting if the person that cuts up oil filters on YT would compare the 2 filters.
2015 Forester XT Touring
Re flushing the oil, the TSB actually sounds like a good idea for any new engine completely apart from what filter is used.
I'd love to hear what a professional engine builder has to say about it.
2019 Subaru Forester Premium
I wish I had read the TSB on these alternate oil filters prior to purchasing them from Subaruonlineparts. I received the filters rolling arounnd in the bottom of a two foot long box along with a set of wiper blades and a cabin air filter I ordered. The filters were unboxed and not shrink wrapped, laying loosein the bottom of the box covered with some crumpled up brown paper. Two the rubber gaskets and separated from the base plates. I was able to work one gasket back into position but not on the other. The filters are blue but do not have the usual Subaru markings on the can, with just a stamp on the end cap of a code, Made in America, SOA6351520815. They are the lowest quality filters I’ve seen in 50 years of changing oil.
Automotive tire Light Material property Gas Auto part
2021 Forester Limited
Wow, you would think they would at least put them in a sealed plastic bag They could have easily wiped out the cabin filter.
Not only is there a shortage of the blue Subaru OEM filters but check out the double oil change procedure for the 6k mile/6 month oil change.
I wish I had read the TSB on these alternate oil filters prior to purchasing them from Subaruonlineparts. I received the filters rolling arounnd in the bottom of a two foot long box along with a set of wiper blades and a cabin air filter I ordered. The filters were unboxed and not shrink wrapped, laying loose in the bottom of the box covered with some crumpled up brown paper. Two the rubber gaskets and separated from the base plates. I was able to work one gasket back into position but not on the other. The filters are blue but do not have the usual Subaru markings on the can, with just a stamp on the end cap of a code, Made in America, SOA6351520815. They are the lowest quality filters I’ve seen in 50 years of changing oil.
2022 Forester Touring
Why would anyone buy those filters when the black Japanese filters are available on Amazon and EBay? Expensive, yes, but quality usually is. When the warranty is up, there are many high quality filters out there for purchase.
2022 Forester Sport
Because there are counterfeits and pricy.
Based on external quality and labeling in addition to the the white packaging they came in, I can confirm that the Tokyo Roki oil filters I purchased in EBAY from a specific seller are genuine.
I have my second oil change coming up in a couple of months and I plan to cut open the original filter, which I kept, and the EBay purchased one which is on my car right now.
2019 Forester Touring
Why even go that far?
If in the USA, The Magnuson-Moss Warranty Act specifically mandates that manufacturers can’t force owners to use OEM parts, such as filters, and it’s the manufacturer’s responsibility to prove a third party part caused damage before denying warranty services.
There are several quality aftermarket filter manufacturers to choose from, with proven track records. The filters the OP purchased were probably made by the lowest bidder on the contract…and it shows.
But, To Each His Own…
Reactions: DavidFst
2020 Sport
meh, too much work, I rather buy local quality brands.
41 - 60 of 79 Posts
