01 forester l
What flows through the trany cooler lines and are they the two smaller lines that run across the lower radiator hose. Any info on part numbers on those lines they look like they need to be replaces.
01 forester L
2001 Forester Slushbox
Yes,those are the trans lines.
You can get replacement rubber line at just about any auto parts store.
Just make sure you get trans specific rubber line,it's different than regular neoprene hose.
Welcome aboard.
You might be better off getting the factory/OEM hose, since they'll be formed to fit & you won't have to worry about making a bend too tight. :wink:
My MODding Journal
98 GM67 + 03 SG
The Automatic Transmission Fluid flows through the lines. There is a ATF/Coolant heat exchanger in the radiator that helps to heat the ATF when cold and cool it when hot.
You can DIY with the proper hose purchased from any car parts store, or purchase the pre-bent and cut to fit hoses from Subaru. I don't have the part numbers, but a call to any of the willing dealerships on this forum will probably yield good results.
