getting a whine from the transmission?? in my 2002, SF5, 4AT, 84,000 miles, only noticeable over past couple of weeks
whine is noticeable above 20mph and pitch increases with speed, the pitch is not altered with gear changes, seems to be coming from the front, only there when I’m on the throttle, when I lift off it goes silent, if I down shift to induce engine breaking it is noticeable again
otherwise the car is running and driving absolutely fine
checked the trans fluid, front diff oil and rear diff oil, all levels are good
any ideas?? thanks in advance
