1 - 11 of 11 Posts
When I put my auto into drive i have to rev it to about 2500 to get it in gear. Once it is in gear, it is fine. There is no problem with reverse. What could be causing this?
none none
Put some trans-X in, its helped some people with that issue. Will it engage if you wait a minute or two or does it have to be revved? And yes, its broken and will likely only get worse, but the trans-x seems to be a pretty good bandaid fix. I'd maybe bring it to a subaru trans shop, or just look for a new trans.
It engages if you rev it. After it engages it is fine.
1 - 11 of 11 Posts
