Peaty said:http://www.scoobymods.com/forums/showthread.php?t=3091
I use Redline Shockproof in the tranny
in the rear I use Redline 75W-90 not the NS but it won't matter the rear LSD is sealed.
http://www.scoobymods.com/forums/showthread.php?t=1772
I want to change fluids in the spring and was thinking synthetic. I see here that Redline is popular. You recommend 75-90 or 75-90ns in both diffs, what do you recommend for the tranny (4EAT)?SuperRu said:For the rear diff on both trannys and front diff on a 4EAT I use Redline 75-90NS. You will be fine using Redline 75-90 too.
After a several hour search over @ Bob is the Oil Guy Forums, I've decided to use Chevron Dexron III in both of our 4EAT's. It's not the fanciest fluid but it is cheap and performs well.XT4ME said:..... what do you recommend for the tranny (4EAT)?
Thanks
The torque converter has a bunch of fluid sitting in it. It doesn't drain out when you remove the tranny pan bolt .XT4ME said:Thank you all for the info. I have also been told by a friend (mechanic) that it's okay for syn's in the differentials but I should stick with OEM for the tranny. Wow! That's a suprise, only 3.5 to 4.5 quarts drain out. I was planning on about 9. Just saved myself some $$ :lol:
I suppose any quality "Dexron III" ATF.jfrankon said:what is the OEM fluid then?
