I’m looking for some help/suggestions/advice.
I have a ’08 Forester Sports X, I bought the vehicle with a salvaged title (rear-end collision) in 2013 and over the years of ownership have found more and more issues/signs that it wasn’t the "easy, body damage only" repair that I was told it was.
The current issue I’m trying to solve is my trailer hitch lights: The right brake light and right turn signal doesn’t work (the U-haul guy let me take the rental trailer anyways) but I couldn't find any blown fuses or any loose wire connections. The wiring harness I purchased years ago is a Curt (model #S0601).
The weird thing was that at night, in the dark, I could see that the right signal was actually continuously on (but VERY dim) and then would sometimes it would just sporadically turn on for a second. I use the hitch a lot but don't use the trailer lights very often, so I have no idea how long this issue has existed.
What/where should I be checking next? Thanks!
@matthewcallahan I see this is your first forum post, so welcome to the forum from Oregon! :biggrin:
The trailer connector wiring is know to get wet, corrode, sometimes burning & melting. This can cause strange issues! I'd recommend checking the connectors first. If those are dry & appear good, post that on this thread & we can dig deeper. :wink:
Also...
Hey Bobby! Thanks for the welcome.
All the connections looked totally fine and normal. No severe damage. I tried using some dielectric grease with no results. (I don't have the trailer anymore for testing.)'
-Matt C.
To start the trouble shooting, first disconnect the chassis trailer connector from that Curt doodad. Verify everything functions correctly... test the connector leads with a meter or test light.
If you need the connector pin outs, take a look at this post I made on another thread. :wink:
If everything tests correctly, then reconnect the chassis connector to the Curt box & test on the output of that converter box. Unplug the cable to the trailer connector, if you can do this before testing, as this will give you a better test.
If it doesn't work properly there, then the Curt box could be faulty? :confused:
If the testing is good at the Curt output, then the problem is at the trailer connector...
