Have just purchased a new MY10 Fozzie X in Australia & have a question about towing points.
Manual shows screw in towing pin in the toolkit - threaded rod with ring on end. This is meant to screw in rear (LH side) or front (RH side). The screw connection is behind a small plastic cover in the bumper.
Problem : there is no screw in point at the rear. The one at the front is fine, but at the back there is just chassis and a couple of bolts.
Is this standard? Has anyone else in Australia looked?
thanks
David
thanks
David
