1221 - 1225 of 1225 Posts
2017 Forester XT CVT
P.S. ^^^ Car is detailed with Adam's Polishes Ceramic Coat. Couldn't be happier with the protection.
2014 2.5i Limited CVT
2014 Forester 2.5i Limited.
538275
Tires - Continental TerrainContact all terrain 225/60/17 (factory stock sizing)
538294
Wheels - Konig "Inception" (from @Discount Tire ) currently limited availability - but now on sale for $50 each!!!!
  • RIM DIAMETER 17"
  • RIM WIDTH 8"
  • BOLT PATTERN 5-100.0
  • OFFSET 40
  • HUB BORE SIZE 73.1
  • WEIGHT 25.4 LBS
No issues with rubbing or any body contact... the tire fills out the well a bit more as it is a bit wider of a rim and the off-set is different, pushing the face out just a tad.
2008 Forester 2.5x mt
Don't have pictures currently, BUT the following does fit beautifully with no rubbing.
2004 Forester XT
Wheel:
Enkei NT03+M 18x9.5
Tire: 245/40/18
Suspension: 2004 STI Struts + Pink Springs (3/4" Saggy Butt Spacers)
2004 Forester XT
Wheel:
Enkei NT03+M 18x9.5
Tire: 245/40/18
[/QUOTE
What offset do you run?also any spacers?
JBP Toaster
2004 Forester XT Automatic
So bit of an update.
Currently running the following specs:
  • Enkei NT03+M (18x9.5 +35), 235/40/18 tires
  • 10mm spacers upfront to clear Brembos
  • 5mm spacers in the rear for flush fit
  • Rear fenders rolled, front fenders self clearanced
2004 XT JDM bits
I've checked the excel doc, but can anyone tell me what tire size worked for them with the same setup?
  • 04 STI BBS wheels, 17x7.5 +53
  • 04 FXT Swift Springs
  • Excel G Struts
Looking for either 225/45 or 50-17 OR 235/45 or 50-17, but worried about rubbing potentially. I know it will need a 3mm spacer at least. Thanks.
