1 - 20 of 22 Posts
2004 FSTI automatic
Looking at what rubber to put on a 18x8.5 rim +44
I am looking to run a 245x45 0r 245x40...or should I play it safe and run 235x40? I havent decided which tire yet...
I am trying to avoid spacers...but 225x45 on an 17x8 +48 was really close to the strut....btw, I am on swifts/GR2's...
The Sub kit guy
2005 Forester X & XT VF39
With a +44 wheel, you I believe you can easily go with a 245/45/18. I think a 245/40/18 looks a little small on Swifts, a 235 tire is a odd size that might cost you more and a 225 would look really stretched on an 8.5" wide wheel. I bet you could even fit a 255/40/18 under there! I'd find a tire place that lets you test fit different sizes. The Discount tire near me let me do that.
2004 FSTI automatic
I definitely wont do a 225..but you really think I wouldn't have an issue with a 245/45? I would like to keep a larger sidewall, not only for comfort, but looks as well, so running a 45 would be key.
I am considering running m&s tires, as opposed to a/s...as I have re-01r for my stickies..
The Sub kit guy
A lot of people have run 245/45/18 on 18x8 wheels whithout issues. Arthrogrian19 even has 245/40/18s on his +51 wheels and he doesn't rub.
I test fit 245/45/18 Contiextremecontacts on my +51 Superlegs and they did clear. It was close in the back, but did not rub.
2004 FSTI automatic
Hmm that is good news...I am just very leary of fitment, as my current 225/45 on an 8'' et48 is very close.
I am researching 245/45...these things aint cheap!! lol
2004 XT
hey JE
my specs:
im on 245/45/18's
18x7.5
Rota Tarmac II's, i believe +48 (need to double check)
still on stock suspension
a few MM's of clearance, i can fit a little bit of my finger in between tire and strut
using BFG G-force AS
eventually gunna go to swifts and i havnt heard of any clearance issues with swifts on stockers, assuming KYB's are exactly dimensions has stockers
here some pics a few days after install
2005 X
I'm running a 18x8.5, +35 wrapped with 255/35's. As for suspension, I'm on '06 WRX wagon struts and STi springs. <<< No issues at all. Overall though, if I could do it all over again, I'd go 245/45 to fill up the gap more, as well as a little more cushion.
2004 FSTI automatic
Discussion Starter #14
+46 with a 3mm spacer, so +43
So did you rub w/out the spacer?
hey JE
my specs:
im on 245/45/18's
18x7.5
The stockers should be very similar...and good to know of your clearance. I am thinking that the 7.5 rim buys you a little room.
BTW, I think the tarmacII are 17'', and the tarmacIII are 18''.
2004 FSTI automatic
Discussion Starter #16
^^yeppers..those are them!! I have the gunmetal TII's and love them.
However, I went ahead and just ordered a 18x9 et42...so running 245/45 w/out spacers shouldnt be a problem now.:Banane17::Banane17::Banane17:
2004 XT
which wheels did you order?
1 - 20 of 22 Posts
