1 - 7 of 7 Posts
Has anyone done this?
I have a '98 2.5l and I need to replace my timing belt.
I have gotten quotes from shops and they range from $250.00 on up for parts and labor. If I can do it myself with little trouble I would rather do it.
Any experienced replies will help.:)
07 x auto
I had mine done by a non dealer mechanic-- same guy who has taken care of the wifes Eclipse for the last 8-9 years. My tensioner tested weak and was also replaced. Whole job was only about $425 parts and labor. Go to a reputable mechanic and have it done--less hassle and work is warrantied.
My .02 worth
I did timing belts and water pump my 99 Forester 2.5 engine this past year. It was a pretty straightforward job. I did have to work a bit to satisfy myself I had correct belt alignment. I had what seemed like 1/2-notch misalignment. After comparing to old belt, I decided all was OK,...and it was. Car runs great.
I wouldn't attempt w/o some form of Subaru shop manual. Procedures are readily available online or you can purchase a e-manual on ebay, which is what I did. I also read a number of testimonials by guys who had done their own T-belt work and one of those was my best source of info.
Use this URL: http://www.scoobymods.com/forums/showthread.php?t=3837&highlight=timing+belt+change
good luck
thanks for the replies I will be getting the timing belt soon and will be attempting this repair. Will post anything that may be helpful to owners in the future.
If you are going to do it....I'd recommend replacing the water pump/ thermostat and all the hoses while you have it all opened up .......save yourself some time / money
1 - 7 of 7 Posts
