1 - 7 of 7 Posts
2001 Forester Slushbox
The real problem is if it can jump one, it can jump five more, and game over.....
Agreed,if you suspect this has happened DON'T run it.
Pull the cam cover off and check with the tooth count method to find out for sure. (search for it,it's on here)
If it has jumped a tooth,figure out why (worn belt,bad idler,?)
More than one tooth or so and valves are smacking pistons,VERY bad.
OK - thanks for the replies - so it is fairly severe. Mine is OK then. I didn't think about the cam and crank sensors - they would of course be comparing alignment between them all the time wouldn't they.
Only one cam sensor on the,well for you the passenger side of the engine.
If something caused the other side to be off one tooth it might not throw a code but it would run like crap.
1 - 7 of 7 Posts
