1 - 12 of 12 Posts
2008 Forester
My '00 starts lightly tcking when the car gets rolling along. It's not the engine as I can put the car in park or neutral and the ticking will go away, even while revving up the rpms.
This is getting highly annoying and I'm having trouble diagnosing the problem...I can't run alongside the car with the hood up!
04 Forester X, MT
most likely wheel bearing and/or CV joint.
if you happen to have wheel covers, it could be them! the clips grasp the outside of the rim and if the cover is damaged or the clips a little loose with age they can make noise. mine drove me crazy for awhile until i figured it out.
try going REAL SLOW and have someone stand outside the car listening to see if it can be pinpointed. try this with and without any brakes on so you can see if any braking makes noticeable difference in the noise.
2008 Forester
It doesn't get worse when I turn. The clicking does get faster along with the car. So there's a correlation...
I know I need to put more tension on th fan belt as it's been slipping on occasion, but the two symptoms don't really seen related.
2010 Forester 2.5 X prem
You probably did this already, but I had the same thing with my VW Jetta and thought I had something stuck on the tire - it was more of a click than a tick but it ended up being the oil was low..I was just able to get to the gas station when the oil light went on, after he added oil the clicks went away. Just a thought.
Silvia
2008 Forester
No wheel covers on the Foz...
It's a very light ticking sound but amazingly annoying.
I've heard a bad cv joint on other cars that sound significantly worse in their ticking or knocking...especially when turning. As far as I knew, cv joints only really made noise when making a turn. Is that wrong?
Thanks for all the ideas so far!!
2008 Forester
Baires60 - did the clicking correlate with the actual speed of the car/revolutions of the wheels? Or with the rpms of the engine when you gave it gas?
I checked the oil this morning to be sure, levels looked ok, if not a little high.
2009 Forester (MT)
First do the following:
1. Park the car in a level surface, transmission in neutral, parking brake off
2. Check the tire pressure of each tire
3. Now look at the treads very carefully (use a flashlight if needed). Look for a small rock, a piece of metal, screw heat, nail head, or anything else
4. Push the far backward or forward to inspect the rest of the treads
If one of the tires is low on pressure, concentrate on that one first. If the pressures are good, then inspect every tire tread. After you have done this, then continue trying to isolate the problem. A screw, nail, a rock, or a piece of metal stuck on the tire will make a ticking sound that corresponds with tire speed.
2015 Forester premium
clicking
I had an 84 Reliant wagon bought new that had a clicking by about 25,000 miles. The dealer said nothing was wrong.
Firestone tried to sell me all new cv joints and struts. Before spending any $ I tried to find the problem. I pulled one wheel at a time and found nothing. Drove it before putting the hub caps back on- it was the hub caps!
1 - 12 of 12 Posts
