Hello, I'm thinking about buying an 01 forester with 60k miles. Anything I should know/look for when checking the vehicle out? I am coming from an 01 Chevy Blazer 2WD. What can I expect? Also are there any other vehicles I should look at before going with the Forester. I really want to stay under 6k used if possible. I want relatively low miles on the vehicle, good gas mileage, lots of cargo space, and all wheel drive.
2019 Crosstrek 2018 XT
If the Head gasket has not been done (assuming its not a Turbo)...it will need to be done. Its a almost a given. If the engine is pulled..timing belt, water pump, idlers, etc should be replaced.
Welcome from Pa.
Welcome from Pa.
yeah, I've heard a lot of people have head gasket problems, but around what mileage can I expect to have problems? Can it happen as early as 60k? What can I look for when test driving the vehicle?
also would it be better to go with an 03 with 85k miles instead?
2014 Impreza Ltd CVT
I would have a mechanic look over the vehicle, inspect the head/block mating from below, looking for seepage. If it mechanically is in good condition, I would just go ahead and buy it. Then maintain the normal service schedule. I would not worry about head gaskets unless they begin to fail.
There are many many 1999-2002 Subaru's, all models with the SOHC engine, out there running just fine for a long long time.
Get as much information as you can, then make your decision.
02 Forester L (sold) Manual
Head gasket education here: Head Gasket Problems - Subaru 2.5 liter engine - Phase 1 and 2
Congrats on getting out of the Blazer...one of the worst SUV designs of most I get to drive. The Subaru will do most everything that the Blazer can do, but without all the negatives of being based on a truck. Expect fuel mileage in the low to mid 20s.
I would be more concerned with finding one well maintained (and possibly with HG replacement receipts) than obsessing about mileage. These vehicles are good for 200,000+ with little drama if moderately maintained. Don't buy one with ANY rust. Timing belt every 90k or risk bent valves. Listen for noisy/growling wheel bearings. Aside from that, there isn't much serious to worry about.
