1 - 20 of 181 Posts
2007 FSTI and X 6 MT
The format is as following for this list
Example
2007 FSXT
VF48 with supporting mods
275whp @6600prms
500wtq @3500rpms
max boost 25psi
Then do the following format for ease when I post it in.
Screen name, MYxx Turbo WHP/Wtq Max psi
This is the VFxx thread for us 4EAT owners
VF23
Philistine2004 FXT VF23, 245whp/282wtq 19psi
VF29
LochSTI--2001 GT--VF29--245whp--16 psi
VF30
edsmed--2006 fxt-vf30-260whp-275wtq--18psi
VF34
VF39
Smooth--2007 FSXT--VF39--250whp/273wtq--16.5 psi
Pleiad7--2004 XT--VF39--247whp/312wtq--18.2 psi
Arthrogrian19--2008 FSXT--VF39--295whp/290wtq--18 psi
Ken Cravillion--2008 FSXT--VF39--278awhp/302awtq
Preacher--2004 XT--VF39--305whp/368wtq--20.5 psi spike to 22psi
sterfore--MY??-vf43 240whp/230tq 16psi
07XTJones--2007FXT-VF39-263whp-369wtq--20psi
VF43
Trinidoc--2003 CrossSports--VF43--249whp/234tq
Tussen--2006 XTL--VF43--291whp/345wtq--18.5psi
BlackonBlack 2004 XT 4EAT--VF43--219whp--230wtq--19psi
VF48
Tuned200-2007 FSXT--VF48--275whp/270WTQ--18.5psi
Canonshooter--2006 XTL--VF48--261awhp/310awtq--20.2 psi
2004 XT PP
VF39 with supporting mods
247 whp @ 6250 rpm
312 wtq @ 3250 rpm
max. boost 18.2 psi
2007 Forester XT 4EAT-VTD
'07 FXT 4EAT
VF48 with STi TMIC
Grimmspeed PnP EMs
MadDad bellmouth catted DP
MadDad 3-inch Whisper TB
Walbro 342
100% stock intake track
Open source tune
241 WHP/326 torque on Mustang dyno in August '09
19.3 PSI (14.3 at redline)
Dyno graph
Observations
1. It looks like I have the lowest WHP of the group so far (for what ever that is worth)
2. Lots of torque, but with a sharp peak at 3200 RPM
3. Car feels tronger than the above numbers indicate
Getting back on the dyno in on 4/10/2010 with new Perrin TMIC, Samco turbo inlet/afterMAF hose, GS AOS, turbo blanket (all already installed) and possibly a GS EBCS. Along with cooler air I hope to see some improvement in my no-better-than-stock-STi WHP numbers.
2007 XT - 5MT ELH, EWG, E85, Kinugawa TD06SL 20G 8cm
turbo inlet/afterMAF why? tuner recommendation? stock torn during VF install?
341-346wtq on a Mustang dyno with VF/Perrin is overly optimistic, must be a newer Mustang friendly dyno.
what psi is the target for the second tune to get those numbers? Please post dyno charts.
I will be very happy if I reach 325wtq with my set-up (see signature) at 20psi.
I just like modding, especially the those mods that are a real PITA to do! But mostly I didn't like the flimsy OEM inlet connection to the turbo and would prefer something a little more substantial.
This is the Mustang dyno at EFI Logics in CT. From what I can see, it reads pretty low. I am expecting a bump in WHP, hopefully to around 260. I'm not expecting much change in torque.
LINK TO DYNO GRAPH
06 Forester STi
2001 SF5 GT
2.0 ltr 4EAT
VF29 with supporting mods
245 whp @ 16 psi
2008 FSXT M/T
dyno charts would be nice, but dont get hung up on the numbers. every dyno reads differently, so its basically retarded to compare unless you were on the same dyno/same day...
Discussion Starter #13
While Im no expert, but from what I have read, corrected numbers are suppose to make it level from location to location. My tuner doesnt give out corrected numbers though.
2008 FSXT 4EAT
2008 FSXT 4eat
295 hp / 290 tq @ 18 psi
MODs
Cobb TBE
Cobb AP v2
Cobb Intake
Cobb Heatshield
VF39
'08 STi TMIC
TubroXS / P&L Motorsports EWG Up-pipe & Dump Tube
Tial 38mm External Wastegate
APS Turbo Inlet
Grimmspeed Phenolic Spacers
Grimmspeed EBCS
KSTech TGV Deletes
Hose Techniques 2" ID 90 degree Coupler
Hose Techniques 2.75" ID 3" long Coupler
Stylin Motors T-bolt Clamps (2 for each hose above)
Walbro 255 and install kit
Check out that torque curve. :icon_wink::rock:
2004 FSTI automatic
2008 FSXT 4eat
MODs
Cobb TBE
Cobb AP v2
Cobb Intake
Cobb Heatshield
VF39
'08 STi TMIC
APS Turbo Inlet
Grimmspeed EBCS
KSTech TGV Deletes
Damns!!! Nice results..who tuned?
91 or 93? I am thinking p&p mani/hi-flow x-pipe and injectors would have complimented your tune, but otherwise it is a hoot to drive!! 4eat FTW!:discomonkey:
2008 FSXT 4EAT
We have 92 in Oregon. Bobby Wintrode at Performance Race Engineering was the tuner - also tuned Sea-Scooby, Smooth, & wakeabyss.
Agreed about the exhaust mani's and injectors. If I go that route, I'll probably do a larger turbo and TMIC (or FMIC) at the same time. And that's partially why I didn't do injectors - it starts you down a slippery slope called "where the heck does this road end?!":biggrin:
2004 FSTI automatic
There is no end!!!!
I figured you went to PRE.. but just czecking..
18psi.& 92... seems quite conservative. I really think opening up bottom end & swapping to STI mani. will give you a bit better high-end response.
BTW....I spiked 22.3 psi today....random pull on a cool day with 3 passsengers.....hmmmm.??
2008 XT Sports
Nice numbers guys. Anyone running supporting mods for their trannys though...like Valve Body upgrade, High Stall TC, Transmission Oil Cooler? If so, where's the best place to source/install these parts? If not, then is this not necessary?
--yamsta
1 - 20 of 181 Posts
