901 - 920 of 3202 Posts
aka Tunergirl
2007 Forester STI 6 Speed /R180
Discussion Starter #902
No rubbing. Brian said we could even clear the D specs without the 3mm spacers but he left them on the rear. To go lower it might require camber plates front and rear.
2007 FSTI and X 6 MT
Stopped by TiC yesterday to talk shop and discuss the potential of the set up. In order to go lower we will need;
coil overs with camber plates
RCE springs with camber plates
None of the options above are cheap so it will have to make due for now.
DPKilty was kind enough to swap me coolant tanks. From everything I have read online most everyone says the plastic tank is better but no one says why. So with that I agreed to swap tank and have his old/ our new one powder coated. A stop over to my buddies house and a day later I have this.
Not bad for $25 for the coating + the cost of stainless bolts and return shipping.
As if you could not tell in the above photo but the above photo contains half of the hella horn harness I made. The other half of the harness comes from the battery and goes to the relay.
Here is its own photo.
Edit, another shot of the harness.
aka Tunergirl
Discussion Starter #907
Less than 2,000 views to go until we hit the big 100,000 mark! I would like to thank everyone who has helped us with this build and offered advice. This has been a great experience.
2006 XT Limited 4EAT
What exactly is happening with that harness? Are the hella horns grounded remotely?
Also what's the doo-dad just left of your fuse box support? Are those your horn/light relays?
Foz is looking great as always. Coolant tank looks racecar. :cool:
aka Tunergirl
Discussion Starter #909
The horns are powered and grounded remotely as for whatever reason they did not like the ground thru the mounting bolt.
That is the Defi Boost gauge sensor.
Thanks!:biggrin:
The wheel well clips are easy. Remove the lower clips and free up the fender liner on the bottom and then slide it free and unclip it from the cover but do not remove it. Then reach into the fender and unclip those suckers.
Exhaust is out for delivery.
