Today was an exciting day so far. I set out with the goal of building the gauge rack. My plan was to make it Removable so I can remove it if I need to. I used the oem radio brackets and bent them inward for mounting points. They were bent outwards earlier but that proved to be the wrong direction for the materials I had on hand.
I must also note that I am using Gorilla glue for now to hold the plastic together and 4 small screws to mount the plastic to the radio brackets. Note to self, Gorilla glue will bond skin.....yikes.
Onto the photos.
Here you can see how its attached.
Note the screws slightly sticking thru the plastic. This will be covered by some sort of wrap so its no big deal.
A couple random shots of the mount so far.
Stay TUNED for further updates. Next up is to drill the gauge holes, cut the controller hole and work on the cover.
