3141 - 3160 of 3198 Posts
2007 FSTI and X 6 MT
Modify the OEM water pump to clean up things.
IMG_1110 by Pam_Cakes_KY, on Flickr
Lets get rid of this ugly hose
IMG_1111 by Pam_Cakes_KY, on Flickr
The water pump outlet that will be removed. The water pipe was already modified.
IMG_1112 by Pam_Cakes_KY, on Flickr
Work on the water pump to begin. Lucky for me, I had an old spare to practice on.
IMG_1165 by Pam_Cakes_KY, on Flickr
I turned down an allen bolt on a lathe and fed the bolt into the port. Using a slide hammer, the plug came right out. (No photos)
Next, I tapped the port and installed a brass fitting.
IMG_1169 by Pam_Cakes_KY, on Flickr
IMG_1170 by Pam_Cakes_KY, on Flickr
IMG_1171 by Pam_Cakes_KY, on Flickr
Water pump installed, and all lines crimped into place.
IMG_1172 by Pam_Cakes_KY, on Flickr
Our good friend Jesse messaged me with a possible solution for my oil cooler woes. He had a brand new STI oil cooler and offered to send it to us for test fitting.
It is a tight fit, but it fits.
IMG_1130 by Pam_Cakes_KY, on Flickr
IMG_1131 by Pam_Cakes_KY, on Flickr
2006 FXT(STI) 6MT DCCD
COME ONNNNNNNN... HURRY UPPPPPPP.... I9 WANT TO HEAR IT... I WANT TO LISTEN TO THE ENGINE... VROOOMMMMMM!!
Finally u r back again my friend!!
Good luck with your built and with everything!!
It takes more than money to do it again... and u know that i know....
All the best Brian!!
Waiting for the bird to fly !!!
Ted
Update time...
Current engine mileage is 1,149.
Parts changed
Koyorad XT Specific radiator thanks to Subtle Solutions with matching Koyo radiator cap
Cusco engine room braces and STI strut bar
Cusco front X brace
Shaved plastic intake manifold
Modified Subtle Solutions alt cover
A special thanks to Cobb Tuning, Subtle Solutions, Corbin at JohnsonTuning, Moore Performance and Grimmspeed for all of the support!
Pics below.
Photos mostly from Subiefest Midwest in Chicago
aka Tunergirl
2007 Forester STI 6 Speed /R180
Discussion Starter #3,158
Time sure does fly, and waits for no man.
After a little debate, we have decided to pull and have sold the IAG stage 2 engine which has 1,266 miles on it. A deal came up for an IAG stage 4 Tuff / Extreme engine with a ton of upgrades including 14mm head studs, o ringed block and decks, killer b pan, pick up and baffle, ported / polished / +1 valves, beehive springs and GSC Stage 3 cams...
This beast is going into Goose as I type this, break in map is in the work from JrTuned and we will push the little Borg Warner to the max. Stay Tuned!
06 forester xt 07 sti 6 speed
This is outstanding!! Cant wait to see the goose with all the boost!!
