Adjust the metal core.....how? In what way?
Just buy a new gusset. Is $60 really that much? In making this adjustment, you've already done 90% of the work.This fix has helped mine, but the very top tips of the gussets are split. Does anyone have a good fix for this besides plain electric tape? I believe someone used liquid electrical tape? how would i seal the splits (about an inch long) with a nice permanent solution?
So far so good on mine...only been 10 days though! But seems solid. I put a couple coats on there, per the instructions. Stuff dries nicely actually, made my craftsmanship look better than it is!I also had to use some liquid electrical tape to seal where there were rips at the top of the gussets. Let's hope that it holds up!
Is that each? It took me longer to remove one gusset than it took to pull both panels, so I wouldn't say 90% of the work has been done. Plus, some people just like doing things themselves.Just buy a new gusset. Is $60 really that much? In making this adjustment, you've already done 90% of the work.
Yeah they are like $70 each from what ive seen. You have to take off door panels. For my car, that money goes toward keeping it running., ill spend a little bit to make it look nice and interior stuff, but its not going to ever see new gussets unless they disintegrate or something. Plus, the fix works well enough.Is that each? It took me longer to remove one gusset than it took to pull both panels, so I wouldn't say 90% of the work has been done. Plus, some people just like doing things themselves.
