As most of you know, the STARLINK app is a sore subject when it comes to the Subaru lineup. It just has way too many bugs and for most of us it doesn’t seem to run reliably at all. But after finally seeming to fix it, I decided to test it for a month, including all the apps like Yelp, Magellan Navi, etc... to see if it would work consistently for me.... and it has!!! So I wanted to share my results with you in the hopes that it may help my fellow Forester owners...
DISCLAIMER: This was only tested on a 2018 Forester Black Edition with the non-onboard Navigation and an iPhone 6s that has not been jail broken. Your individual results may vary or not improve at all!!
With that out of the way.... the fix to make the STARLINK app stable and the apps within it to work as they were designed is simple: IGNORE THE DIRECTIONS AND VIDEOS SUBARU PUT OUT ON HOW TO OPERATE THE APP. If you start up the STARLINK app on your phone and then start it up on the infotainment unit... it’s going to crash, at some point. So the fix, at least for me, was simple... DO NOT START THE APP ON THE PHONE WHILE USING THE INFOTAINMENT UNIT!! Just connect your phone via Bluetooth or USB and that’s it!! Just select STARLINK after it comes to life on the infotainment unit and pick the app you want to use. During my tests.... none of the apps failed as long as I had cellular service. They all worked flawlessly! I hope this helps anyone that is frustrated by this issue.
