154455 Views 761 Replies 62 Participants Last post by  abacall
361 - 380 of 762 Posts
It sounds like your transplant is coming along nicely! :cool:
I did in fact check the plugs! They had antiseize, and the gap was correct. Not sure if they were iridium, but I'll pull them at 30k anyway to check.
If they were NGK Iridium spark plugs, it would say "Iridium" on the porcelain. :wink:
^I wasn't looking at the porcelain! :lol: Du-oh!
Rechecked... yes they are iridium.
Oh... lookie what we have here....
It's still dirty, I haven't gotten around to cleaning it or repainting the intake tube. Also need to install the washer reservoir, and order the AC belt tensioner so that I can get that up and running, and get the accessory belt cover back on. I'll get more/better pics then. She runs like a champ... fired right up after I got the oil sytem primed (fuel pump fuse pulled, coil pack unplugged, crank until oil light goes out). All of the hobby shop employees gathered to see it fire up. :lol: Went for a test drive, and when I came back they had cleaned up my work bay for me! They're not supposed to do that. :huh:
They're suppose to last 60K miles, I'd guess twice that. :wink:
Congratulations on the successful heart transplant! :cool:
How many miles before you can pour on the coals? :confused:
:lol:
1000 miles. Though, generally speaking, I always keep it under 4000RPM unless I need to get moving. It definitely has much more spunk than the old engine did... I've got about 10 miles on it now. The STI Group N engine mounts are cool as well. Little more noise, and vibration at idle, but you can feel the engine smooth out as it moves up through the RPM range. :biggrin: Gotta love the boxer.
Did you go with an upgraded pitch stop? :confused:
With all the rain here this year... another storm coming in tonight, we may not get to our '03 Forester project until next month! :frown:
No upgraded pitch stop... I was told from a fellow BH owner that it didn't do anything for his car but upgrade the noise. :lol: My OEM pitch stop is metal... not like the plastic one that our Foz has. :confused:
Sounds good. We're staying with the stock... yes plastic, pitch stop on our Foresters. :icon_eek:
I was going to mention your intake monifold eariler, how it blends in nicely. Glad you didn't go with red. :wink:
4
One year with the BattleWagon...
Well my friends, we're closing in on a year with the BattleWagon... it's certainly been a ride. :woohoo:
Then, and now...
It appears we have something in common! The end of this month makes one year for my '07 FSXT & the start of my Member Journal! :cool:
Your engine compartment looks great, but me thinks you need to add back in some contrast... like the factory yellow pieces? :confused:
DANNNNNG. man i've missed a lot.
Lookin' better than ever man!
:smile: You gonna have an anniversary cake for the foz? :biggrin:
I've got plans to add back contrast. That battery will be replaced (possibly the tiedown too, and I'm thinking about an eBay oil cap. If anything, they will be red accents instead of yellow. :icon_razz: I like how the positive lead covers on the battery/alt cables pop against the black. Dunno if you noticed, but the airbox is now wrapped in aluminum tape. Dropped my IAT's by around 20deg! Still need to revise the intake to 3"... that will take some work. I need to find another airbox to use while I'm working on it.
^ LOL! No, heat-proofed. :raspberry:
Looks great m8. As I mentioned earlier. Your car gets newer as time goes by. :biggrin:
No cake for the Forester... I'm too poor after feeding it all those MODs! :icon_eek:
Yes, I noticed the airbox & figured it was for heat reduction. That's a decent drop in temperature, should be good for some hp gain! :cool:
Holy crap, man that is awesome for such a simple mod. Did you do more than one layer?
It was one layer, but they do overlap a little bit at the seams.
20deg difference was on the same road at the same water temp, outside temp, etc, about two hours before the baseline run. Car had been running for the same amount of time... I think the biggest advantage for this mod is highway use. In traffic, it will still heatsoak the box, albeit not as quickly, so IAT's will still go up if there's no air going through the engine bay.
I think it'd look nice with your intake. :biggrin:
Check out this thread for my future plans:
CAI using 3" pipe and stock airbox - Subaru Impreza GC8 & RS Forum & Community: RS25.com
I'm kinda torn on this. The aluminum wrapped airbox look actually looks pretty good & has been proven to help keep the intake air cooler on your setup. Wrapping the intake pipe with aluminum will help, but IMO, not that much. Here I'd have to weigh the clean looks of the pipe with one that wrapped with aluminum. :confused:
