Chaps,
just wanted to draw you attention to TEIN suspension products, which is my suspension fo choice at the mo.
I highly rate having a 4-wheel laser alignment done also...even if it's on your current suspension. Having a bit more camber on than normal can transfrom your ride...trust me... even if it's on the standard suspension !!
These are the ballpark prices with discount for their various suspension combos via a highly rated supplier/installer, widely used by several Forester drivers in the South East (based in Surrey):
1 year UK manufacturers warranty, fitting available on all items
Popular parts and prices are listed below including vat
Superstreet M damper set
Height, rebound and compression damping adjustable, compatible with EDFC and
solid adjustable top mounts for more precise handling and a greater range of geometry adjustability
Forester 97-08+ £1,081.00rrp £972.90 discounted
EDFC
Electronic Damping Force Control allows you to adjust suspension from inside the car at touch of a button whilst moving
£346.64rrp £311.98 discounted
Bonnet Dampers
Bonnet opening aid available for most models
£117.50rrp £105.75 discounted
Strut Braces
Increase chassis rigidity and handling performance, EDFC compatible
Forester/WRX/STI 92-00 £135.13rrp £121.62 (each) discounted
Forester/WRX/STI 00+ £152.75rrp £137.48 (front) discounted
£135.13rrp £121.62 (rear) discounted
Drop me a PM and I'll put you in contact.
Rich
ps. this is just advising on a good quality supplier and a good product, so I make no financial gains out of the recommendation.
EDFC
Bonnet Dampers
Strut Braces
Rich
