1 - 7 of 7 Posts
2008 2.5 XT 5 Speed Manual
I am currently rebuilding my turbo. According to ARD Tuning their 11 blade turbine wheel delivers a better top-end with a marginal loss in spool time (300 RPM):
11 Blade TD04L Turbine Wheel
Their product looks very similar to that of the TD04L-4-12T2-VG used on VW Crafter 2.5 diesels and Ford Transit 2.4 Diesels:
https://www.ebay.co.uk/p/Genuine-VW-Turbocharger-2-5-TDI-Crafter-Td04l4f-49377-07420-076145701c/1661465143
More affordable versions are also available:
https://turbospareparts.eu/en-detail-902493863-turbine-wheel.html
So I bought the components at a local supplier whose website lists the turbine wheel and shaft for R 600 ($ 43 at the current exchange rate).
Below are pictures of my old turbine and compressor wheels next to the new ones. The new parts are on the left in all pictures.
07 FXT
My opinion ... why bother.
The TD04 is a tiny turbo, upgrading it won't change that fact. If you do swap in the modified turbo you WILL want/need a tune, so at that point you might as well have upgraded the turbo to a VF or similar, and get some real gains. Even the VF is small for a 2.5L, don't get caught up worrying about spool with these little turbos, it is such a non-issue. Maybe if you drive off-road and need low end grunt, and only then maybe.
Purely for curiosity's sake :smile2:
I am rebuilding the turbo in any case to eliminate any possible oil leaks while I am rebuilding my engine and tuning the car afterwards. So to add a little experiment at low cost while I am at it does not seem too bad.
My turbo has a flanged connection to the intercooler, so I am limited as to second-hand replacements/upgrades and VF52's are not widely available second hand in South-Africa...
Discussion Starter #7
Good day!
I finally completed the project. See dyno graphs below for torque and power distribution over the rev range :)
1 - 7 of 7 Posts
