2004 2.0 X
Ok, last two days- reversing from start up. First time- I stalled three times however this time I ready and immediately dipped the clutch to avoid stalling.
Select reverse and let the clutch out- car revs drop right down then recover and swing down again (I've already dipped clutch to save from stalling)- happened again today and this time the engine light came on. The car didnt stall and set off fine with no power loss, power-dip etc.
Other points:
1. The car hasn't overheated.
2. No squeels
3. No loss of any fluids
4. The car pulls fine in any gear.
Could it be the *exhaust emissions sensor or air-sensor throwing a fault code?
Maybe needs the sensor cleaning and resetting?
At somepoint reading this topic you are thinking 'you have to go down to a 'subaru dealer'....which leads to my next question- they are 25miles away. Do you think its 'safe' hypothetically to drive that far with the engine light on?!
(non-turbo manual petrol)
1998 Forester
I can't really help without knowing what code is set. In the U.S. it is safe to drive with the light on unless it is flashing.
2004 2.0 X
When you say what code is set- what do you mean?
Worsecase, Im worry it could be a oil pump (if thats possible?). idle control valve- not a biggie etc.
2004 2.0 X
When the check engine light comes on it will set a trouble code in the engine control module (computer).
How do you read this as a consumer though? Only the dealership/garage can read this using a PC?
04 Forester X, MT
In the states many parts stores will read the code free with a code reader.
Otherwise you could buy your own code reader. Here it it would pay for itself if it saved you 2 or 3 trips to a garage to pay a diagnostic fee (depending on garage fee and how fancy a reader you purchased).
