1 - 16 of 16 Posts
2009 Forester 2.5X
Found my coolant level a little low for the first time. Requires dealer only long life coolant for ~$30/ gal. Any less ridiculously expensive compatible alternatives?
none none
Is yours the new blue super coolant? If so you have to use the same kind to top off, which is only avail at dealers. However, if you go into a dealer they may top it off for free (my dealer always topped up everything when I brought it in for an oilchange)
2009 Forester 2.5X
I do all my own work, and prefer to keep essential fluids on hand. Looks like the pricey blue juice is the only way to avoid potentially shortened coolant life, corrosion, or other problems, unless the aftermarket comes out with something.
2009 Forester (MT)
If it's under the warranty, the dealer should add antifreeze free of charge. Well, they would charge Subaru :)
In my view, the anti-freeze should not disappear unless there is a mechanical problem in the motor, or a leak somewhere.
2009 Forester 2.5X
Discussion Starter · #11 ·
Where are you seeing this low level? radiator, expansion bottle?
I wouldn't worry about it unless it is a substantial change from full.
Coolant level is checked at the overflow bottle. It has been at normal level every time I have checked it since new until now- I have about 17k.
Water is one of the main ingredients in coolant- ~50%, so it will evaporate gradually over time. I live near sea level, but recently made a couple trips up to 9K feet in the mountains, so that may have had something to do with it. Not sure dealer would cover it under warranty unless there is an actual leak. It would be under routine maintenance like an oil change.
2016 Forester XT AT
My coolant level was a bit low at this last service as well (42,000 km) and in addition was only good to -20C. So the mechanic drained a bit, and topped up the rad. This will get me by till I can get to the dealer to find out why the level dropped, and I will at that time get the system flushed and re-filled with the proper stuff. I just hope I can get it done before my trip to Northern Alberta next month!
2010 Forester 2.5X
Topped up with what? What about the conditioner?
Fast & Dirty
2009 Forester XT 4 speed auto
hahaha
-20C isn't good enough for anywhere in Alberta. Best be getting that looked at before starting the trip.
2016 Forester XT AT
hahaha
Its usually not good enough for around here at times either!
I did not see specifically what he put in but it was the same weird colour and he said it was compatible. it was only a liter or so, I hope that not having the conditioner in that small amount won't be a big deal for the week or 2 it will be in there.
1 - 16 of 16 Posts
