Ok, so I'm a little confused and maybe someone can clear things up.. Here is what I know
calipers/brackets
all considering I use my 16" rims
My SF has the same setup as a 2.5RS
I know about the 02-03 WRX Rotor upgrade by changing the brackets.Still using 16"
Now here is my question.
Pretty much all rally cars run 15". (team dynamics motorsport rims)
Now for my car to run 15", I need to grind my caliper a bit to fit the 15" OEM caliper/bracket.
I'm guessing I will never be able to fit upgraded WRX rotors/brackets under 15" mags?
What do the rally cars run as setups? They still have OEM calipers/brackets and run just better rotors/pads?
Thanks for the info
calipers/brackets
Thanks for the info
