1 - 20 of 646 Posts
The Sub kit guy
2005 Forester X & XT VF39
(Work in progress)
The Subaru Forester come from the Factory with a 5x100 bolt pattern. So do several other Subaru models. This means several styles of OEM wheels will fit the Forester. This thread will only cover the wheels that FIT the Forester.
Subaru also used the 5x114 bolt pattern, but these are currently only used on the 05+ STi and all models of the B9 Tribeca. This thread will not cover those wheels since they do not fit the Forester.
Subaru mainly used 3 different offsets depending on the vehicle. +48mm (Forester, Baja, Outback) +55mm (Legacy, Impreza) and +53mm (STi and 98-2001 Impreza RS). No other offsets were offered from the factory in the Forester's lifespan (98-current).
Since the Forester uses a +48mm offset, the larger offset wheels will bring the tires closer to the struts. With a +55mm WRX/Legacy wheel, you man have rubbing issues (on the struts) if using a tire wider than stock.
For Reference the OEM Forester sizes are:
15x6 +48mm offset with 205/70/15 tires
16x6.5 + 48mm offset with 215/60/16 tires
17x7 + 48mm offset with 215/55/17 tires
18x7.5 + 48mm offset with 225/45/18 tires (Not offered in the US)
If you know of any OEM Subaru Wheels I'm missing, please let me know so I can add them to the list. If you have pix for ones missing let me know. I've borrowed a few pix from members post too, but I will remove them if you don't want them up.
I've tried listed weights when available. They may be off a bit since it comes from several sources but I'll try to be as accurate as possible.
A lot of the wheel info comes from this site:
Understanding Tires and Wheels: FAQ, Subaru sizes, codes
16" OEM wheels
98-2001 Forester S
16x6.5 +48 offset
17 lbs
2002 Forester S
16x6.5 +48 offset
17 lbs
04-06 Forester XT, 08 X, Sports X
16x6.5 +48 offset (Clears some 4 pots)
19 lbs
03-07 Forester X (steel wheel)
16x6.5 +48 offset
23 lbs
03/04 Forester XS
16x6.5 +48 offset
20 lbs
05/06 Forester XS/X P.P.
16x6.5 +48 offset
20 lbs
02-04 WRX
16x6.5 +55 offset
16.5 lbs
05 WRX
16x6.5 +55 offset
17 lbs
2002-2004 Impreza
16x6.5 +55 offset
05/06 Impreza (multiple models including OBS)
16x6.5 +55 offset
2007 Impreza
16x6.5 +55 offset
2008 Impreza
16x6.5 +55 offset
03-06 Baja (silver or gunmetal)
16x6.5 offset +48
1998 Impreza RS (Gold Only, Clears 4 pots)
16x7 offset +53
16.5 lbs
1999 Impreza RS (silver only, clears 4 pots)
16x7 offset +53
16.5 lbs
2000-2001 Impreza RS (clears 4 pots)
16x7 offset +53
16 lbs
97-2004 Legacy GT (mesh)
16x6.5 +55 offset
18.5 lbs
98-2003 Outback (Various models/colors) 03-08 Forester L.L. Bean
16x6.5 +48 offset
05 Outback 2.5i
16x6.5 offset +48
The Sub kit guy
Discussion Starter #2 (Edited)
17" OEM wheels
2007/08 Forester XT, 2009 Forester
17x7 +48 offset
24.5 lbs
2008 Forester XT Sports Edition
17x7 +48 offset (Thank you SirWilliam)
2009 Forester XT
17x7 +48 offset
WRX STi V7 (JDM) (JDM gold, EDM Gunmetal)
17x7.5 +53 offset (clears 4 pots)
17.5 lbs
2004 WRX (JDM/EDM) (Gold, Silver, Gunmetal)
17x7 +55 offset
19 lbs
2002-2004 WRX "optional" wheels.
17x7 +55 offset (clears 4 pots) (BBS Forged wheels)
15 lbs
2004 WRX STi (gold or silver)
17x7.5 +53 offset (clears 4 pots, clears Bembos) (BBS Forged wheels)
16 lbs
06/07 WRX
2008 WRX
17x7 +55 offset
Legacy B4 (JDM)
17x7 +55 offset
18 lbs
05-07 Legacy GT, 08 Legacy 2.5i
17x7 +55 offset
07/08 Legacy GT- 2008 Outback Sport
17x7 +55 offset
06/07 Outback
17x7 +48 offset
20 lbs
06/07 Outback XT (silver) Outback L.L. Bean (Gunmetal)
17x7 +48 offset
21 lbs
2008 Outback XT/LL Bean
17x7 + 48 offset
Saab 9-2x BBS RK
17x7 +48 offset
16.5 lbs
The Sub kit guy
18" OEM wheels
Forester STi (JDM) (Thanks MikeyMike)
18x7.5 +48 offset
25 lbs
Forester STi (JDM) (Silver & Gold)
18x8 +48 offset
20 lbs
06/07 Legacy Spec B.
18x7 +55 offset
21 lbs
2008 Legacy Spec B
18x7 +55
2008 Legacy 3.0R
18x7 +55
2014 Forester XT
18" X 7" +48
Approx Weight +/- 25.3
Part Number 28111SG020
MSRP $359.95
P.C.D. 5X100
Harbor Fright
2005 XT
Let's not forget the red-headed step-cousin Saab 9-2X family of OEM wheels...this is one:
BBS RK, 17X7, ET 48, ~17#, perfect fitment (crappy pic, though).
07 Forester XT
Don't forget these uggies. Stock for 98-02 Forester L models. As in "LOWEST" trim model.
Any thoughts about pictures of the wheels actually mounted on a Forester to give people an idea of how they look mounted ?
► Edit - moderator's note - the image on this post is not recoverable. :frown:
admin
Who could forget the optional 15 alloy wheel. :icon_wink:
The Sub kit guy
Discussion Starter #14
I left the 15" off the list since they do not clear the brakes on a lot of the Foresters and there are dozens of different styles that came on the Legacys and Imprezas. I can always add them if people want.
2008 Forester XT Limited
2008 XT 17" x 7" wheels
Nice thread sea-scooby.
Attached is a photo of the 17x7 wheel from a 2008 XT Limited (Canadian)
Just took delivery yesterday, so there's a bit of dust on the wheels - sorry about that.
Use the photo as you see fit.
Regards,
CdnGeorge
99 Forester
I'd like to see the 15" information as I have a 99 Forester L. I just put on some 225/60-15 tires on it and it looks pretty good. There isn't much clearance to the strut though so I wouldn't want an offset that brings the tire closer to the strut.
1 - 20 of 646 Posts
