Ok, so I haven't seen a dumb question here today, so I thought I'd add my own idiocy to the world.
I have a friend with a "set" of wheels for "cheap". Here's the issue that gives rise to the dumb question.
He has 3 wheels that are 17x7.5, et53 and one wheel that is 17x7.5, et48. They are matching rims though (same maker). If you run a 5mm spacer on an et53 wheel, you are effectively running et48, right? So, could you run either one 5mm spacer on the same "axle" (fronts or rears--likely rears on the Foz), or 3 5mm spacers on the other 3 wheels to make them all effectively 48mm?
I told you it was a dumb question. I personally don't see any detrimental issue with it, but something just seems "off" about doing it.
What say you guys?
What say you guys?
