just wondering if anyone has had the same problem. I changed the front diff with mobile 1 synthethic 75w-90 and did a drain and refill on the transmission for my 05 xt using subaru atf. Car seems to shift fine and drive fine but just makes this strange rattle between shifts.
Had a difficult time getting the fluid right in the trans, started checking it cold to get a better baseline. At this point I'm wondering if the noise is actually coming from the front diff. the rattling sounds like gears trying to find each other?? and is only noticeable when driving lightly at low speeds as the transmission shifts.
car has 160XXX
car has 160XXX
