1 - 8 of 8 Posts
2003 Forester XT Manual
Hopefully you've experienced this too and know a little fix for me to do at home.
When depressing the accelerator (calling it fat, useless etc) it seems to work in steps rather than in one smooth analogue motion. It seems to be a bit sticky and heavy meaning smooth progress is a bit of a pain.
Any thoughts on how to sort it out?
David
2015 Fiat van Man stick
You can have this adjusted electronically via a mapper. You can make it more linear or you can make it real progressive.
If yours is really bad perhaps it is dying?
Simple fixes huh? I've got some WD40 around so i'll try that.
Use something like Silkopen for cables. It's a lot better. Best option is a new cable though if it's the original?
2000 Forester S Turbo Manual
Also give it it a bit of a clean up at the throttle body end. The grease on there can dry out/gunk up.
1 - 8 of 8 Posts
