1 - 15 of 15 Posts
Are these parts standard in FSTIs and would you see any benefit from the upgraded transmission mount?
TRANSMISSION MOUNT FOR 6M/T
japanparts.com : PARTS DATABASE
I would think it is not the standard mount since it says:
Reinforced rubber, Uprated from Stock
GEAR QUICK SHIFT LEVER ASSY / 6MT
Fleetwood's car has a short shift (not sure of the make though).
In my 205 I upgraded to GrpN engine mounts (not transmisison mounts though) and the car felt better.
Also to fit the transmission mount is it a gearbox out job? If so there is no point in getting one.
Cheers!
Discussion Starter · #2 ·
Anyone? :)
Is it a gearbox out job to fit both items?
2006 sti
Quickshift is not gearbox out.
Don't think the mount is either but I may be wrong.
Peaty did a write up some years ago on another forum, can't seem to find it though.
Have you seen these on ebay 230433027077.
Paul
Discussion Starter · #4 · (Edited)
No, I wasn't aware of the B&M one. I have also been offered a 2nd hand GFB short shift which has a really short throw, it was fitted to Legacy specB and have been told that the throw is shorter than 1st to neutral of the existing setup(!) but can be adjusted a bit longer if I wish.
Both the B&M and GFB look very similar but the Sti seems to have a totally different design (yes it is assembled whereas the others are not but the Sti seems to have more parts to it)
Has anyone tried any of them? The problem with short shifts is that they make gear changes slightly stiffer normally.
2006 sti
I have a quickshift fitted. It's an Agency Power one I got new off of ebay.
It certainly shortens the throw, but also stiffens the gear change a fair bit.
It does take getting used to.
Saying that the wife drives it O.K.
Also changed some other bushes on the linkage for poly' ones. This also increases vibrational noise a bit inside.
Paul
MY11 WRX STi Sedan 6MT
Prodrive/Sti supply the "complete" gear change mechanism whereas most after market suppliers just supply the gearstick.
Quickshift Gear Change - 6 speed
Have the Prodrive/STi 5MT complete quickshift on mine and its great.
My ex partners SF used to have a Rally Design short shift "stick" which was very similar in action but slightly taller.
Fitting these also makes a big difference..........
Kartboy 6MT stay bushing combo
Discussion Starter · #8 · (Edited)
Cheers Don!
The one advertised in the subaru UK site is a Sti one(?) and is it the same for a 6MT Impreza and Forester I guess, so should fit?
If this fits:http://imwww.imgroup.co.uk/IMGGB/WW...73CB891786787BBA802575830051A909?Opendocument do I still need the stiffer bushings? Doesn't it come with stiffer bushings?
I have driven a WRX/GB270 with a prodrive (or Sti?) shortshift and although it was nice the gear changes were slightly stiffer which put me off but I guess you get used to this as fozzysti says.
Cheers Don!
If this fits:Quickshift Gear Change - 6 speed do I still need the stiffer bushings? Doesn't it come with stiffer bushings?
Prodrive/Sti no difference as all WRSport upgrades were originally sourced by Prodrive for Subaru UK including the STi parts.(They now bring in some of their own)
In the US, SPT perform the same function.
It comes with a slightly stiffer front rubber bush but not as stiff as the "poly" bushes.
Discussion Starter · #10 ·
As per PM Forester quick shift appears to have a much reduced "stroke" compared to Impreza one. 30% compared to 10%)
I wonder if the original fits are the same?
The one I have fitted is......
UK part no: SACC2439 or Prodrive part no: SDST3501079000 (no idea of current cost/availability from dealer)
Specified as "Quickshift Forester 98/99MY" but fits all upto MY05
Transmission Quick Shifts for SUBARU
This one reduces the height of the gear knob and does away with the dampened lever.
Could also be achieved by just replacing the lever for aftermarket version.
1 - 15 of 15 Posts
