1 - 15 of 15 Posts
FXT Alumnus
Does anyone know the physical differences between a Stock 04 STi header versus my stock OE 2004 FXT ?? I have an opportunity to pick one up cheap and want to judge the value of it.
Thanks in advance...
2004 Forester XT
I believe the XT header give you better low and midrange grunt, while the STi header gives a better top end. This is what I remember reading, others who have them will hopefully chime in.
2008 SG Model D
You won't gain that much from a stock STi manifold. Why don't you just port and polish the stock FXT one? Or just buy a used borla or aftermarket if you want real gains.
G
I added the STI manifold and I noticed on my logger a few more degrees of ignition advance at high rpm, and a higher MAF voltage, which tells me I'm making more power up top. It was noticable, but not huge. I didn't really port them much, just took off the burrs and the spots I thought weren't real smoooth.
05 XTi FMIC
Crosspipe is of larger diameter in STi.....
Asphalt Surfers Unlimited
2004 Forester XT
Can someone please re-host the photos?
The Wee-Todd-Did links no longer work, and the old board is gone.
GTP? You out there? I can host the pics if you want.
99 UK S-turbo
Now thats the sort of research that is needed, fair play to him!
Simon
11 sec club
04 Cayenne TT
I've got a set of the 06 FXT manifolds and a set of 04 STi manifolds. The left sides are identical. The right side where everything comes together is much more open in the STi one.
04-05 FXT same as 06-up WRX - smaller diameter
04-up STI same as 02-05 WRX - bigger diameter (edit: 06-up FXT ?)
i think that's right...
2004 FXT
Seems odd that the STI manifolds would be the same as the 2L WRX manifolds...
1 - 15 of 15 Posts
