1 - 12 of 12 Posts
2005 Forester XT SOLD
I think that I read somewhere that the OEM crosspipes appear short and the flex section stretches as things are installed. I hope this is correct because I took up about 1/4 to 3/8 of an inch this way. Does that sound corrrect?
Second. This set of Manifolds are off of a friends car with 7K miles and no problems or leaks. On both sides of the crosspipe the center of the mating surfaces do not come together like the outsides(near the bolts) do giving the appearance that the surfaces are not mated correctly. Is this normal with the Grimmspeed gaskets and the ring in the center of the gaskets? I have torqued to 60 lbs to try to compress but no luck.
Thanks for any help!!
2016 Outback and WRX CVT
^ Shouldn't even need a pit/lift - or even jackstanding the car, for that matter. :smile:
But that's indeed what I'd do.
From a cold start, you should have more than a few minutes of working time to determine if there's a true leak.
Grimmspeed customer support thought it was a problem. They sent out new 2X thick gaskets today no charge! Thanks Grimmspeed!!!!
I will spend a little time over the next few days checking the surfaces with a straight edge and tune them up a little while the gaskets are on the way. Ill report back.
Is it normal to need to "pull" the OEM crosspipe to the manifolds?
Discussion Starter · #9 ·
OK I guess more new guy stuff. Reading Canonshooter's post I did not follow the correct sequence. I went to my old small block/Land Cruiser increase torque in a circle inside out. I tightened everything a little at a time. Not really a circle on this application.
So did I ruin something or do I just need to loosen it all and then retorque the crosspipe and then the manifolds to the heads?
2004 FSTI automatic
Bingo. If I recall, you tighten the manifolds to the heads last.
Do this..^^ after you get your thick gaskets.
So you are using sti p&p elbows, and stock x-pipe? I hope the oem x-pipe is p&p too...If not, get the highflow one from GS or importimage. The x-pipe is almost more retrictive than the elbows.
You are getting a re-tune? If not, you will flow more air, and possibly throw a cel.
Discussion Starter · #11 ·
Yes this is just part of a total upgrade. I will be installing a VF48 tomorrow followed by a tune next week.
It is also the PnP Grimmspeed crosspipe. I will remove everything today and check the surfaces with a straight edge. If there are high spots I wil spend a little time with a file to bring them in line a little more.
Discussion Starter · #12 ·
So I reinstalled with new gaskets and torqued the crosspipe first. It looks better but only time will tell.
So far the biggest PITA was removing the stock bpv hose to replace it with the new STi one!
MY VF48 ARRIVED TODAY!!!!!!
1 - 12 of 12 Posts
