I'm looking to get a set of the poly rack bushings, and whilst browsing kastles corners site it mentions that the 25mm set was for RHD, and a 30mm set I assume by default is for you yank LHD steerings.
I wasn't aware there was any difference in bushings! I was all set to buy a 30mm set, and glad I stumbled on this since my JDM S/Tb is RHD.
Can you guys confirm for me that there is a difference, and what does the 25mm and 30mm refer to, is that the width of the bushing? I can take a crawl under my ride and confirm I have a 25mm wide bushing.
SuperPro works also. Same thing as Whiteline without the Whiteline name or price tag (made by same people). I'm pretty sure the size difference refers to the width. Go ahead and climb under and check it out.
Ok I can confirm that the JDM RHD SF's are 30mm, so a bit of misleading blurb there from kastles.
