I have tried search on here, I can't find the info I need?
After the new engine was fitted I went to Powerstation for the remap.
During the remap Andy Cook said something about replacing a switch as there was hesitation.
To get to this you take out the Gear Lever to get at it.
I really couldn't hear all of what he was saying as it is noisy in there!
Anyway couple of days after the remap CEL came on.
I went to Foresters who plugged it in & the mesage was Heat Sensor Exhaust Temprature.
They replaced the sensor & reset the machine, no problem.
I really haven't pushed it since the new engine was fitted.
However, a couple of days ago on boost, it cut out then CEL came on, & a split second later poewer back.
When I started the engine the next day CEL off, driving well no problem.
Yesterday, I had the misfortune to be stuck on the A127 Jam into Southend On Sea.
I was behind a Van that kept his engine running the whole time, CEL came on & stayed on.
When I got onto the M25 on boost, cut out again.
I rang the Foresters & explained about the "switch?"
They said it is a starter switch by the gearbox & they will replace it for me.
Questions.
A) What is a Starter switch?
B) What does it do?
C) Will it solve the overboost?
D) Do you think it is a remap issue?
Thanks.
Regards
AM
Questions.
B) What does it do?
Thanks.
Regards
AM
