1 - 2 of 2 Posts
2007 forester xt
Hi I just got a 2019 VF48, 2013 STI TMIC, TurboXS catted dp, MagnaFow axle back, would any one have a Map to share I would like to compare to OTS stage 3 map?? for fueling and boost setting I am just starting to learn about tuning.
Also, does any know if i change the wast-gate actuator to vf43 could i run the Cobb OTS stage 3 with the TDO4 pill?
2001 Forester STi 6spd with MapDCCD and 535hp
If you are going to try and tune it yourself, take that pill and throw it in the garbage. Those things cause more headaches than they are worth once you are outside of OEM specifications.
1 - 2 of 2 Posts
