We had bought a bunch of Retaining Wall Blocks from Lowes which I put in the back of the Forester to hall from the store to home.
Made multiple trips from the store to home.
Now there seems to be a squeaking sound coming from the back of the Forester.
At first I thought the foam had been misaligned and was rubbing against each other under the top cover.
I removed the foam and the top cover and the sound was still there.
I made sure everything is installed correctly but the sound is still there.
Sounds like foam rubbing up against other foam.
It's really annoying.
I am starting to the think something got tweaked by the weight of the stones.
They were about 4 x 12 inch block stones but we only carried maybe 20 at a time ( 1 stone is heavy of course, around 22lbs each).
Anyway, wanted to see if anyone has ever experienced anything like this after hauling something heavy?
I figured the Forester should be able to handle up to 400 to 500 lbs of load at a time (I figured about 20 stones at 22lbs each would be between 400 to 500lbs).
Subarus creak, rattle, and squeak. It is a feature you will want to get used to. I'm on my 5th and they all came with this factory option free of charge.
Try greasing up the rear door latch. I had a creak start about 6 months after I bought mine and that's what it turned out to be. Never would have guessed it though till I climbed in the trunk while someone else drove my car around.
