2004 XT
not sure why but i keep getting a squeak from the rear on both sides (L/R) every time i hit a bump or speed bump on cold days. i have a cobb sway bar but already had them greased 2X! thats not my issue. any other ideas? i hear that it can occur where the body meets the frame or something? can anyone help?
Yes, it can be caused by the cargo door especially in the older models. What model do you have? I think some people lubricate the rubber stops or something similar.
2004 XT AT
Mine emits a few noises (not really squeaks) from the back when going over bumps for the first few minutes of driving each time I use it. I put it down to the self levelling units sorting themselves out, but that's just a hunch.
There is no frame. Re the cargo door theory, you could try driving a short distance with the tailgate open. Then again the increased road/exhaust noise might drown out the squeak if it's still there!
-- Steve
There is a large rear "cross-member" that attaches to the body; so I suspect that is what's meant by "frame". Probably check it's mounting bolts for tightness wouldn't hurt.
