2004 Forester XT 5MT
no you don't 'need' the stock one but if you had/have one it's just extra benificial! i have mine with a stock shield as well to keep heat down! Painted the back side (turbo side) with flame proof paint to try as an added bonus for help.... no data on it though as far as if it actually helps or not... ha ha
2004 Forester XT
That is a good idea...the flame proof paint. If it does keep heat down by running both, I will just go to the bone yard and get another one when I find time.
just DON'T do the baking part!! when you use the flame proof paint it calls you to cure the paint.... ie. bake it in the oven for three cycles, three temps at three periods of time... so just paint it and let it dry for about 24hrs then just bolt it on, the heat cycle from the turbo will cure it!
this is the color and brand i used: bought it from Advanced Auto Parts
VHT SP102 - VHT Flameproof Coatings - Overview - SummitRacing.com
2004 Forester XT
2004 Forester XT
Discussion Starter #7
word lol only defect that comes out of baking as i found out is you basiclly melt the SPT logo ha ha DOH! :chair:
I am glad that you found that out for me! I promise you that I would have had the DOH moment myself so don't feel bad! :biggrin:
2004 Subaru FXT MT
Need is such a strong word...lol
Ideally, you should keep every little bit of heat energy in the exhaust until after it passes through the turbo. Without going into the details, it boosts efficencies and response time of the turbo.
And in that the IC is right next to the turbo, and the more heat transferred to it, the lower the efficencies.
So, my reply to your question of need is no, you don't need it, but you should do everything that is reasonable to keep your turbo exhaust hot and your intake/IC cool.
I personally just run the stock heat shield with a custom made turbo blanket. Nothing wrong with the SPT shield, I just modified my car to the point that I couldn't mount it...
2004 Forester XT
Discussion Starter #9
NEED
:biggrin:
