We are struggling with spluttering at 2500rpm and above 5000rpm to such an extend that it will not go past 5000.
The management is stock as far as I know.
The motor is a combination of an early 90’s jdm WRX bottom end 2mm head gaskets, S-turbo heads and cams.
Four into two into one header and TD05 from above mentioned motor with the 90deg inlet.
I have replaced the MAF with a oe unit because the previous one looked like a pirate part.
According to the diagnostic unit all seams well but she still stutters at 2500 and if I keep her in second gear she will eventually go to 6000 but with a lot of spluttering and spitting.
Boost is set to .7bar
Where to next?
Where to next?
